centurion
Hi all
I was concerned about the drive shaft on my paralever gspd but on taking it out it seems fine a slight stiffness on the lower joint at extreme angles but otherwise smooth and no obvious play.
BUT when I turn the gearbox output coupling by hand it feels very notchy and positively tight in at least one position. It selects gear fine and other wise seems ok.
Is it about to go bang, I havnt drained and looked in the oil yet to see if there is any debris.
The reason I suspected the shaft first was when pushing it backwards out of the garage I could here a distinct clunk . This seemed to go away after a ride when it was warm. Is it the gearbox or am I becoming para (lever)noid.
Thanks for any advice
Centurion
Centurion
