For info here's a little background...my '03 1150 has been stored in a garage with battery removed (on optimate) for the past couple of months. Prior to this the bike was running perfectly (standard) with nothing other than an Akrap can.
I picked up a Remus y piece in the meantime and got round to fitting it last week, which is when I also slotted the battery back in. Tried it with the Akrap...was nice but not for me, so removed it the next day. I noted the throttle cable thing had slipped out after lifting the tank so I slotted that back in place. Anyway...since then I've used the old girl half a dozen times & have noticed that she stalls every so often. Sometimes after starting her up while putting gloves/lid/case on and sometimes when pulling up somewhere and pulling in the clutch. It's like she's running fine, but all of a sudden the idle drops a little and she stalls...sometimes she managed to pick herself up again though.
I've read through previous posts, like water in the tank...yes I washed her thoroughly last week, but that wasn't the first time for her. Checked that throttle cable...was in place. Did the motronics (sp?) ECU reset, despite Steptoe's advice not to bother...no change. Don't know where any of the other sensor are. I'm guessing it's the lambda sensor? I fecked a sensor on my 306gti many moons ago & had similar problems. Must say though I was very careful when removing and fitting the sensor when changing to y piece & back again.
Grateful for any feedback
