I'm leaving my winter springs on with spring oil. Bit concerned this may invalidate my warranty? There was a fella at the garage who filled my crankcase with a 78% nitrogen 21% oxygen mix for £10 after they'd done my oil - bargain.
If your concerned about the oil, ring Rainbow.
Mine has used virtually no oil in 300 miles but judging (from your photo) the colour of your headers after the first 50 miles you ride a lot harder than me. My exhausts are a nice amber after 300 miles and I didn't think I'd been hanging around.
Mike
Spoke to rainbow today and they say a litre every 1000 km is acceptableThink I need to buy shares in Castrol
I honestly don't know why my headers are so blue, I've honestly not ridden it that hard. Under advice from Rainbow I haven't thrashed it![]()
Keep it topped up to the max, there is less space for the oil to thrown around and it will use less this way! Someone will say thats "bollox" but a top ex BMW engineer / service manager and race engineer with GP bikes gave me this advice, and I think he know more than most here!![]()
They shouldn't use that much oil if you run in the bike properly. So best take it back to the garage to have it checked that you haven't damaged the engine. Not too much of a problem if you plan to sell it within 2/3 years as the fault will most likely affect the next owner.
I have some Castrol GP (mineral oil specifically for the 1200GS and GSA). They can cost up to £12 per litre bottle at a BMW dealer. As you are a fellow member I can let you have a one for £9.![]()
I'm not using a car oil, since I rev my boxer high from time to time, and bike oils (I'm told) have a better shear resistance. (This is MY solution, I'm sure somebody will come along and tell me I'm a fool - duh).
Hi, oil threads don't get many serious answers anymore, since there's a lot to choose from, and everybody has a preferred oil. But here are some basics :
For a new bike like yours : upto the 6000 miles service only MINERAL oil is recommended by BMW. This has to do with the proper running in of your engine. If you dealer wants to put in synthetic oil at the 600 mile service, he's not doing a good job. Really.
After the 6000 miles service, you have a free choice between mineral/semi synthetic/synthetic oil. They all have their pros and cons, and although there's enough scientific info about, this is where everybody has a personal preference, so it's up to you to do a search and then decide.
What oil specification (e.g. 20W-50) you put in your bike is also up to you, though I'm sure your dealer will have stock oil he wants to sell. Have a look at your manual for approved oil specifications.
Here's MY opinion : my bike's my baby, and my baby gets the best. Synthetic doesn't deteriorate as fast as mineral, it doesn't go acid over winter, and generally speaking its' qualities remain stable over a longer period of time than mineral. So synthetic it is. Then I'm thinking of better lubrication at cold starts, and better lubrication at low temps, so I want a 10W. I've read that the '50' reduces distribution chain clatter. So MY choice is synthetic 10W-50. I'm not using a car oil, since I rev my boxer high from time to time, and bike oils (I'm told) have a better shear resistance. (This is MY solution, I'm sure somebody will come along and tell me I'm a fool - duh).
Now, back to your bike : it's new, and it's using oil. That's common, nothing to worry about, but oil consumption should decrease as your mileage goes up. BMW's statement that consumption of 1L oil per 1000Km is acceptable, is only to avoid owners complaints. It's actually very uncommon to get this high kind of consumption. Some use more than others. Mine consumes 1/2 L on 10000km, but more when riding in the mountains.
Then, reading the oil level through the looking glass can give puzzling results.
This has to do with oil expanding as it gets hot. 4L of oil can expand to 4,3L when it's hot. The BMW manual EXPLICITLY says to check oil when engine is hot. This actually means cold oil will show a lower level seen through the looking glass.
Why does BMW want you to check the oil level when engine's hot ? If you check oil level when cold, and are confronted with what you think is a too low level, you may add too much oil in the cold engine. As it expands, the excess oil may get in touch with the engine crank, and get frothy, and air doesn't lubricate. Also, the surplus of oil may get burnt, and that's no good for the catalytic converter.
So, for a good reading of oil level through the looking glass : ride your engine 'till it's hot (as can be seen on dash). When stopped, put it on centre stand. Wait a few minutes to let oil flow down from all parts of the engine (esp. oil cooler), and then check.
This is the basic info for your boxer. The burden of choosing the oil spec (xW-y) and sort of oil (mineral/semi/synth) I leave to you.
Ah yes : if you have chrome headers, they'll turn blue. If you have the standard headers, they'll turn amber and then rust (which it actually is not).
Enjoy your new bike !
wow thanks for such an in depth and informative reply
I do check my oil in the correct manner by the way.
It does appear that even BMW mechanics can't agree on oil either, I received a reply yesterday saying that they use a running in oil for first 600 miles, and that I should use 20-50 semi synthetic. There's no wonder I get confused
I have to say I like the blue tinge to the headers![]()
I have run it is ad recommended so I won't have damaged it, if anything it'll be a faultThey shouldn't use that much oil if you run in the bike properly. So best take it back to the garage to have it checked that you haven't damaged the engine. Not too much of a problem if you plan to sell it within 2/3 years as the fault will most likely affect the next owner.
I'll take on this minor task.
Broadly, bike-specific oils are inferior to an equivalent car oils as they don't have friction modifiers* which would shag a wet-plate clutch.
As the R-series don't have wet-plate clutches, it's not an issue. Use car oil to give your engine the best and save a few quid into the bargain.
Greg
*From the Amsoil website:
Another issue with using an automotive type oil in a motorcycle with a wet clutch is that many automotive oils have friction modifiers. Friction modifiers in automotive oils tend to provide increased frictional reduction and offset a portion of the fuel economy lost when the U.S. Government mandated a reformulated gasoline for emissions requirements. However these friction modifiers can be detrimental to proper wet clutch operation and can cause slippage
.What oil is chosen is very much a personal thing. All kind of factors come into play, scientifically correct or not. Some simply won't care, some consider price, what the dealer has in store, ambient temperatures (Morocco vs. Scandinavia), the interval between oil changes, etc etc. I found the learning proces interesting, and then deciding actually quite fun.
I don't think a 'best' oil exists, that is : an oil that will suit all. That's why we have these neverending discussions on oil.
........... I've read that the '50' reduces distribution chain clatter. So MY choice is synthetic 10W-50..........
