Mr T Member UKGSer Subscriber Joined Jan 9, 2016 Messages 54 Reaction score 1 Location Waterlooville Mar 31, 2017 #1 Does anyone know if the brake pedal can be adjusted? It's a bit to low and want to raise it slightly.
BigRedUn Registered user Joined Aug 7, 2015 Messages 284 Reaction score 0 Location South Oxfordshire Mar 31, 2017 #2 I don't believe it is.
unicycler Active member UKGSer Subscriber Joined Jul 21, 2014 Messages 384 Reaction score 3 Location N. Ireland Mar 31, 2017 #3 No. I tried to adjust mine in the past. After 2 mile smoke from calipers and brakes locked solid. Never again
MrMcNamara Registered user Joined Apr 24, 2015 Messages 324 Reaction score 0 Location Saddleworth Manchester Apr 1, 2017 #4 Mr T said: Does anyone know if the brake pedal can be adjusted? It's a bit to low and want to raise it slightly. Click to expand... you can adjust it but it will lead to tears!
oddshapedballs Registered user Joined Sep 12, 2012 Messages 1,928 Reaction score 5 Location Wiltshire Apr 1, 2017 #5 Heat it, bend it?
stick Well-known member UKGSer Subscriber Joined Jul 10, 2009 Messages 4,380 Reaction score 575 Location Lord Lytteltons Door Mat Apr 1, 2017 #6 Mr T said: Does anyone know if the brake pedal can be adjusted? It's a bit to low and want to raise it slightly. Click to expand... I think you can get a plate that will make the pedal thicker using spacers , I have done similar using the touratecc pedal extender ... google is your friend
Rederic Active member UKGSer Subscriber Joined Dec 2, 2009 Messages 270 Reaction score 1 Location west lancs Apr 1, 2017 #7 I had the same problem with mine, even the dealers said it felt low compared to new bikes they had no cure though so I knocked this up to raise the pedal worked for me
andylel Registered user Joined Apr 20, 2013 Messages 512 Reaction score 0 Location Hertfordshire, England Apr 1, 2017 #8 I wonder if a GSA pedal would fit straight on. They're adjustable after a fashion.
