I've just been having a look at my esa rear shock and it seems to me that when you use the button to change from soft to neutral to hard, all you are doing is changing the damper settings and not the actual spring rate as the spring length does not seem to alter, unlike when you change the load ie 1-helmet to 1-helmet+suitcase to 2-helmets, where you can clearly see the spring top mounting electronically extend downward about 10mm for 1-helmet-suitcase to about 20mm for 2-helmets.
If this is correct and the white springs that are now fitted as standard have a spring rate that is factory set for proper lardy riders, the light-weights among us will always feel the bumps more as playing around with the damper rates can only have a limited amount of effect on the actual bump setting because we are not softening the spring at the same, am I correct? Perhaps someone on here knows and understands the suspension in more depth and will enlighten me?
I'm about 12 stone and on bumpy roads particularly town or village roads with lots of road repairs my bike has a harsh ride, however if I stick my lass on the pillion who is about 9 stone the bike is nigh on perfect.
Perhaps I need to drink even more beer and bulk up a bit more.
Having moaned about the quality of the ride on bumpy roads at low speeds, once I get the bike out onto a decent fast flowing A or B road that has a half decent road surface I tend to ride in dynamic mode which defaults to the hard ride setting and the bike is just sublime...it's fantastic and I love it.
So when this ride issue that only some of us are unhappy about is fixed, which I have no doubt will happen, the GS-LC will be an even better bike than it is now and will 'comfortably' remain the best all round big adventure bike that money can buy.
