daylyons
Hello, all this talk about changing the oil filter is fair doing me head in. I am in the process of changing the filter on a 1991 R100GS with oil cooler. There is no paper element. There is no metal ring either. (Although in mitigation I see that the factory may have push-fitted one onto the outer face of the filter chamber, but it certainly does not want to come out - this is a 1991 bike).
That just leaves three rings:
I. The little stumpy black collar, which goes on the big hole of the filter and is the first to go inside the engine.
II. The smaller of the two rings (black) which sits on the other end of the filter.
III. The big white ring, which locates nicely in the outer ring-groove of the outer engine plate.
That's it, if you have a 1991 bike. No paper elements. No metal rings.
ALso I have just finished cleaning my petrol taps. Now I need two new column filters and the green pipes that go inside. Mine had completely rotted away and it took ages to get them out of the tank. The bike is getting revenge for not having been ridden for ten years.
Weather is lousy here in Kingston and it is also my birthday.
daylyons
daylyons
