Northern Monkey Registered user Joined May 13, 2010 Messages 761 Reaction score 0 Location preston, lancashire Nov 4, 2020 #1 Just swapping out gsa box for one with a taller 6th and found this , is it just slave or something worse? Thanks Sent from my iPhone using Tapatalk
theoneandonly looking over the edge UKGSer Subscriber Joined Mar 14, 2011 Messages 7,555 Reaction score 2,701 Location sutton, surrey , england. Nov 4, 2020 #2 do them both.
Northern Monkey Registered user Joined May 13, 2010 Messages 761 Reaction score 0 Location preston, lancashire Nov 4, 2020 #3 Do what both? Slave and gearbox? Sent from my iPhone using Tapatalk
Packer Appreciating Scotland UKGSer Subscriber Joined May 13, 2005 Messages 8,881 Reaction score 27 Location Glasgow, Scotland Nov 4, 2020 #4 If the clutch master cylinder fluid level is OK and you haven't had to top it up it's gearbox. Gear oil has a very strong and distinctive smell.
Northern Monkey Registered user Joined May 13, 2010 Messages 761 Reaction score 0 Location preston, lancashire Nov 4, 2020 #5 Ah roger , I’m replacing the box anyway so that kind of rules the need for that I’ll whack a new slave and seal on and see how we go Sent from my iPhone using Tapatalk
DrFarkoff Grumpy Ole Git!!! UKGSer Subscriber Joined Jun 27, 2006 Messages 14,246 Reaction score 2,323 Location Islandmagee, Co Antrim NI Nov 4, 2020 #6 Do you have Felt seal on your pushrod?? If not update to the later one with a felt seal
Northern Monkey Registered user Joined May 13, 2010 Messages 761 Reaction score 0 Location preston, lancashire Nov 4, 2020 #7 Yes I have the felt bit thanks Sent from my iPhone using Tapatalk
Northern Monkey Registered user Joined May 13, 2010 Messages 761 Reaction score 0 Location preston, lancashire Nov 4, 2020 #8 Packer said: If the clutch master cylinder fluid level is OK and you haven't had to top it up it's gearbox. Gear oil has a very strong and distinctive smell. Click to expand... Bingo, wiped the orifice and it stinks of gearbox oil, clutch reservoir is normal so looking gearbox rather than slave Thanks Sent from my iPhone using Tapatalk
GS Addict Registered user Joined Jul 25, 2016 Messages 95 Reaction score 1 Location B.C. Canada Nov 16, 2020 #9 A quick way to ID the crud is to see if it will mix with water. No mix - oil Mix - brake fluid
theoneandonly looking over the edge UKGSer Subscriber Joined Mar 14, 2011 Messages 7,555 Reaction score 2,701 Location sutton, surrey , england. Nov 16, 2020 #10 GS Addict said: A quick way to ID the crud is to see if it will mix with water. No mix - oil Mix - brake fluid Click to expand... useful little tip.
