iTunes
Baza 07
Wirral Merseyside
Morning all, could anyone help me with this issue please, I’ve downloaded an album from the ITunes Store it’s in MP4 and it’s on a usb stick, but it won’t play on my car stereo, it needs to be in MP3 format and the question is,how do I covert it,I’ve changed the settings in ITunes to MP3 but still no joy,what’s the easiest converter for me to use.
Thanks in advance 👍
To do it in iTunes just select the music file, chose convert and off you go.
You may need to first set up the file type you need to convert to: go to Edit, Preferences, import settings and choose mp3. That should do it.
Cheers bro, gonna give it a go later 🤞👍
Top Result fellas Eagles now on usb and playing in car,but the tracks are all jumbled up for some reason, any ideas why please 🤔
You may need to open the file tree on your USB and number the tracks in the order you want them. if it goes into double digits add a 0 at the front of the single digit numbers.
Here’s a twister, I plug my USB in the car and all the tracks on the Eagles album are jumbled up, but all the other albums are fine,so when I plug the USB in my computer the tracks are all in the correct order 🤔😵‍💫🤯
Any ideas please, it’s not a “Biggy” it’s my OCD going haywire 😲🙄
Cheers Baza👍
Your car stereo is probably old-ish and doesn't read the metadata in the mp3 files.
Metadata indicates Album, Artist, and a few other info including track sequence.
When you export the tracks in Mp3 from iTunes you have to save them with the naming format: 01_Title_Artist.mp3
Haven't used iTunes in a decade, but I think it can do that format automatically and should be in the options.
Is the Eagles album a compilation by any chance? iTunes can get in a right pickle with them if you're not careful.
Did you do what I suggested here? It'll sort it.
Cheers Baza👍
Cheers Baza👍
No mate because when i plugged the USB in to the PC they all lined up perfect,plus whats a "File Tree" ????
Thanks for helping (y)
Were they all named: 01-xx, 02-xx, etc? it's the structure of the files in a list. It will sort from the first digits in order.
That’s what I thought mate, at least it plays 👍
Thanks for your help 👍
I've recently used MP3Tag free software to add the metadata.
Now, for the first time in years, I can select an album or artist on my Zumo XT rather than having a jumble.
This is the first time i've had any probs,with downloading music from anywhere,glad MP3Tag
has made your life easier (y) (y)
