I've found it! The holy grail in chain lube!
I used this PTFE lub on the last chain drive bike I had (Triumph Tiger 800xc) & found it to be very good. The only downside I found was that it didnt seem to prevent corrosion & the outer link plates went rusty. I resorted to the occasional wipe with scottoil oil. Could have been the quality of the chain or not re-applying often enough or after a wet ride? See how you get on with it.
Chain saw oil is great for anti corrosion and will polymerise after a while so really stays stuck. It's cheap as well.
Thanks Nutty, Brilliant stuff :D I cleaned and lubed the chain on my Africa Twin yesterday ,amazed how it cleaned up, just hope this lube stays on the chain instead of my number plate, :rolleyes:
Just to resurrect a thread, based on a few positive comments about SDOC in this thread I tried a can of SDOC cleaner and white spray and have been totally impressed by a) how clean the chain is when you use the cleaner and b) the lack of fling-off. Just purchased a 6 can pack (3 cans cleaner and 3 cans of white lube) as its by some margin the best stuff I have used. No idea how well it actually lubes the chain but time will tell Im sure.
So thanks Nutty & Redrick :beerjug:
RBW.
15 minutes from grimy to this
<a data-flickr-embed="true" href="https://www.flickr.com/photos/rickmidgley/29811672001/in/dateposted-public/" title="Chain Cleaned and lubed BMW S1000XR"><img src="https://c2.staticflickr.com/6/5500/29811672001_63c31d23fc_c.jpg" width="800" height="481" alt="Chain Cleaned and lubed BMW S1000XR"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
What on earth do you use to degrease the sprocket, wheel and chain guard? That looks like it came straight out off the showroom.
Ordered a multi pac of cleaner and lube from MCRR and a new chain brush from evilbay. Cheers for the heads up :thumb2 :D
Dont use those 3 sided chain brushes they feck the O rings
Get a half inch paint brush and cut off half way down
Oh didnt know that !
Yes they dont tell you that
On paper it looks a good bit of kit as it does 3 sides at a time but the bristles are very stiff and harsh.
The SDOC chain cleaner is bloody brilliant stuff and once you have sprayed it on just use a paint brush to agitate it a bit, leave it for 10 minutes and hose it off !
I tend to dry the chain with a cloth afterwards before re applying lube.
Graet stuff, looks like ive wasted £2.80 then :eek::green gri :augie
The problem with sticky, non-fling chain lube is all the dust and crap off the road sticks to it and forms a nice grinding paste. I'll have a chain oiler any day and put up with the fling.
