I've got a new garmin 660
bardicastle
london
Can anyone tell me why my 660 map disappears when i go over 65mph and then reappears when i reduce speed to under 55mph. I have checked the setting but can't find any reason as to why it does this....:confused:
Also have worked out how to put my routes on to the 660, I toke it for a out for a try and it straight lined the route. I.e if there was a series of bends on the programmed route, the garmin would show all straight lines, instead of following the bends.:confused::confused:
I think i've explained that properly!!!!
hi john
60 mph = speed enabled autozoom
do i have to have it in off position?
hi john
sorry, how do you check if pc maps are the same as 660? or is that to complicated to explain
