Jesse Panniers
FD2
Liverpool England
I've got a set of Jesses that I'm planning to sell. They came off an GSA and have a fitting system based on a long heavy mounting bar. I'm looking for instructions too make sure its complete before I move it on. To come to the point, I've checked Jesse and can't find anything, can't seek to find a contact number. Anybody used this system that can help? Or show me how I'm blind and can't see where the answer lies in plain site...thanks
Sadly not, but thank you. I'll post a photo of the gibbons tonight. Or maybe I just advertise them as they are and someone more motivated can sort it out!
Is it the mount where there are slots on the top that the panniers slide into and you push the over centre latches to clamp it all into place?
Will see if I still have the instructions but in the mean time.
Offside, big C bracket, loop from footpeg and a round tube clamp to bolt onto frame. This clamp should also have a bit flatbar bolted onto it which connects to the footpeg loop.
Nearside, big C bracket, loop for footpeg, bracket that extends the exhaust mount. At the back there is a plate that sits behind the number plate for moving the indicators. There is a lower bent tube that connects the 2 big C brackets together behind the mudguard/numberplate mount. Lastly there is another bent tube with flat metal in the middle that connects the upper big brackets together and also connects to the rear rack mount.
