John gemi stage 16 chip r1150gs
Popsicle2
Member
great tey
Hi All
Have got a chip on order for my old girl😀 any tips after fitting for first start up ie just fire it up or open close throttle, igintion on off a few times etc , thanks for any replies, ride safe all
Good luck! I had a couple of different John Gemi chips on my 1150 twin spark and all they seemed to do was make it hard to start. Wish I never bothered.
Just turn it on and go .It will be faster.mostly in the upper rev range .
In my opinion a john gemmi chip and a y piece is the two best improvements you can do to an oil head
Thanks for the replies, all fingers crossed it works ok, will give it a try and see how we go
I've had the mans chips and it's never ended with the bike being worse...👍
Honestly, dont think it’s necessary if the bike is properly set up. Timing spot on, valves adjusted and properly synced.
Might not but if you've tried it and it feels better then it's better... It's a debate, especially on 1150s that has been some of the longest and most boring threads on the biking web...😉😆
