just passed 20,000 miles on my Jan'07 1200GSA
Jeremy
Devon
and not a single problem, just run in:aidan
nice to hear lets hear some more good news me 3300 miles 09 gsa no probs
Was you expecting trouble then:augie
Not at all although some of the doomsters on here would make you think otherwise. Fourth GS and no issues, must be luck of the Irish.
"Doomster" here - I think I'll have to redress the balance... :augie
June 08 12GS, currently on 10,000 miles:
new ring antenna at 3,750m
new rear shock "
brake line fracture at 6,500m (during my IAM test), resulting in
new engine crank case
new gearbox (damaged gearbox cover not available separately)
new rear subframe
new swingarm bearings
Bike now booked in for new rear LED light cluster (the original one is letting in water).
Great bike, cr*p quality, great warranty. Having a good dealer helps!
Either I'm unlucky, or I ride too much :roll
Achim
new rear shock "
new rear subframe
Achim
unlucky i would say Achim:eek: I have same bike same age same milage not one problem
June '07 bike...GS ADV currently 25K+ miles smooth as a babys a#*......
Antenna ring changed at compaign,computer update,new battery fitted after failure less than 1year,fuel pump driver failure at 23K replaced under warranty.
Bike runs so smooth @4-45000 rpms.
Valves settled in nicely,last 2 checks the valves were pretty much dead nuts on needing no adjustments,throttle sync almost perfect too.
Brake pads still plenty of life,since 22K added less than 100ml of oil.
Just regular maintenence,gas,and GOOOOO!
Sept. '07 - 6200 gets better & better
2 new mirrors, Dealer thought they were a bit vibey at last service (warranty of course) saved me cleaning them!
