Just Serviced with 15W-40 Engine Oil
Jer
Member
Aberdeen
I’ve just had my bike serviced at BMW Aberdeen (John Clark) and they used Magura SB 15W-40 oil instead of 5W-40. Checking with some of the other guys in our club their oil changes were also with 15W-40.
Question, has BMW changed the required oil grade for the 1300GS ?.
So if I have an engine problem later on then am I at risk of voiding the warranty ?
Cheers Jer.
Cheers Jer.
Interesting (y)
There was an article on YouTube that mentioned some manufacturers of new cars were backtracking on their use of 0 & 5 wt oil as they were seeing more cases of premature engine failure and so we’re going back to heavier oil.
Cheers Jer.
I would email and request confirmation that the oil used meets with BMW Motarrad specifications and does not void the warranty. Simples?
Google search
Magura SB 15W-40 is a highly specific, high-performance mineral oil traditionally formulated for agricultural machinery, central hydraulic systems, or older heavy-duty braking and leveling systems. Because it is a heavy-duty 15W-40 mineral oil, standard high-quality 15W-40 heavy-duty diesel/multigrade engine oils or multi-application agricultural oils act as direct physical and chemical equivalents.
Cheers Jer.
I wonder if the dealership that did this service might give you a proper answer
Google search
maybe the OP misread the invoice and this was for an oil change in the backhoe accessory on his BMW Tractor?
Cheers Jer.
Had my 1250gsa serviced there a month ago and noticed the same thing on the invoice. I just thought it was a typo or something on their system a bit amiss.
If you're worried just ring them up and ask, sure they'll be able to explain.
Mike
Mike
Did you ?
