Cook1e
Good day gentlemen,
A few weeks ago, my 2001 R1150GS with around 53K on the clock started smoking on startup. A big cloud of blue oil smoke which disappears in a few seconds. Nothing changed that I know of and still doing it after a service last week.
I am aware that this is and always has been a feature of BMW boxer engines when the bike has been left on the side stand for a while - my old R80 used to do it.
My question is: why should this just start? I have had the bike about 3 years and put about 30K on it in that time. Serviced regularly, minimal oil consumption (sometimes half a litre or so between services) with Valvoline VR1 20w50, same as the last 3 or 4 services - Silkolene 20w50 semi-syn prior to that. Compression pressures checked last service 150psi right/180psi left with engine cold.
So, nothing that I know of changed, yet the smoke went from none to a cloud between one cold start and the next. Performance, ease of starting and oil consumption all OK. Unlikely to be a broken ring as compression OK.
I'm not unduly worried, I know other bikes do this all the time. I also know that if I park it on the centre stand it will probably cure it. I'm just curious
Any thoughts?
Any thoughts?
Compression is well in spec though, so I don't think the engine's wearing noticeably
