Stripped the box and found the input shaft bearing has gone, so will replace all the bearings and seals.
Does anyone have any recommendations on where and which bearing makes are best for the job
Thanks Matt
Recently there seems to a lack of technical assistance forthcoming in here - must be holiday season...
I've never done a gearbox but my 2p:
It may sound unlikely but check with a main dealer for the bearings. Surprisingly they can be cheaper than the likes of
motorworks for certain things like this.
If you go to a bearing supplier I'd get 'named brand' European bearings rather then the Chinese imports that some sell. I'd use OEM seals (from either dealer or
Motorworks etc).
Are you geared up to reshim the box when you reassemble? I've not done it myself but I've read about it on here and ADV - apparently it needs either a special tool (fits instead of the gearbox endplate and allows you to use a depth micrometer) or a modified old gearbox end plate so that you can set the shaft end float.
While you're in there it might be worth checking and possibly changing the clutch master cylinder and gear position indicator switch. Same for the clutch - adds to the cost but if it's worn consider a clutch kit too (never just change the plate).
Check the shafts for grooving in the way of the seal lands - this caught me out when doing the gearbox output seal on my 1100 - the shaft had grooved and the new seal leaked after 100miles or so.
Hopefully someone who's done this will chip in.
Good luck (and take some pictures / consider writing up your experiences)
