K & N
Frontbrake
SW London
So anyway , I'm about to put a Y-piece on my 1150 and was wondering if it would improve things even more if I popped a K&N air filter on to improve the 'suck' as well as the 'blow' .
Cheers in advance .
Frontbrake
There's a lot of 'K&N filters are really bad at filtering dirt' type threads about at present. google is your friend here.
Although the K&N bashing has some way to go before they catch up with 1200GS bashers ;)
Cheers in advance .
Frontbrake
only improvement was that its cleanable, save your money unless u want a washable filter, :thumb
I'd stick with the paper filter,K+N seem to attract even more crap that the paper,And you have to make sure there always oiled,If not the holes in the gauze will let all that crap into you engine.
There great for the ultimate horsepower,but would not use for road work.
Suited for race engine, With regular stripdowns,So should be perfect for the 1200 hex lump :augie
My bike is a 'keeper' and so for that reason there is absolutely way i would fit one of these things to my bike.
would that be NO way, or just way??
i have a pipercross filter installed and its ok, nothing to shout about. just regular take out, clean, refit.
Couldn't agree with you more.... :thumb
Standard filter for me, no improvement in performance or economy with the K+N and the possibility of inferior filtration.
Stewart
:augie
the gauze only holds it together, theres filter material between the gauze, its good at filtering, but still dont recon it offers anything other than its cleanable:thumb2
I believe it is possible to buy specialised air filters for riding in desert conditions. Anybody know where?
1150GSA
Saudi :Motomartin
I would assume the stock filter very capable but if you are really adamant, you could put an oiled foam filter/sock on the end of the snorkel, after sealing the airbox joins up well with silicone grease. Possibly looking at reduced power though.....
Common sense dictates that the only way you can get more air through a filter of certain dimensions is bigger holes or more holes. And I cannot see how you can get more holes without the filter falling apart.:augie
