Of what relevance is it how many posts I've written about it? Did you count the number of people who mentioned the problem? Did you note the fact that its been mentioned in tests in various moto-mags, one of which (CycleWorld?) even went to the trouble of removing the steering damper in an effort to solve the problem? The front end weave certainly wasn't a product of anyone's imagination.
I wasn't suggesting it never happened, but it is ancient history. I had to search back 2 years before I could find any mention of it which suggests to me that the issue was rectified quickly. Certainly a lot quicker than Triumph reacted to the brake problems on the various 1050 models.
Now you're just being deliberately obtuse. Your claim was that the length of time Triumph took to address the issue suggests that the problem wasn't an easy one to fix. My example shows how absurd that reasoning is. There is no logical relation between the length of time it takes before a manufacturer addresses a known problem and how difficult the problem was to address.
So the issue of a leaking tap which you can't be bothered to fix is comparable to a motorcycle manufacturing taking 2 years to rectify a problem? I don't think so. Maybe it was a case of Triumph not bothering their arse for 2 years until the outside pressure was too much and they HAD to do something about it, but I stand by my assertion that it took them 2 years because it wasn't that easy a solution. If it was and they had worked on it as soon as they were getting reports of the problem then the issue would have been rectified in 2005 instead of this year.
Were these failures you mention common to the breed? I'm genuinely curious, since I've heard no similar reports. If you can direct me to a Triumph website where complaints like these have been posted, I'd very much like to read about them. And I promise not to dismiss them merely because they happen to be on the internet.![]()
I have no idea because I didn't discover any Triumph websites until 2004. But I do know one thing...................one so called reputable US based Triumph website has been known to delete threads where there is criticism of Triumph, so you won't get the full picture there.
You must still be trying to get your tongue out of your cheek after writing that Andrew. Apparently, to avoid any accusation of denial, you believe everything
