Keep the K&N Air Filter or not?
JohnnyBoxer
North Yorkshire
Just been doing a bit of spring cleaning on the 1150GS Adv and removed the K&N airfilter for it's annual service
Plenty of crud in there:eek:
Cleaned it all out and used the K&N service kit to degrease, wash and left it to naturally dry out
Once dry I'll re-oil with K&N oil and pop it back in
However whilst doing it, is there any engine or performance benefits to running a K&N air filter?
Bike has stock headers and collector box with CAT and a Remus Road Legal Can (no.............I'm not thinking about a Y piece -uggh)
I've run one for 7-8 years now and don't know if it's any better or worse:nenau
Should I go back to the paper BMW filter and just replace every 12-24k miles - the R11RT runs the stock BMW one and performance doesn't seem compromised
Road miles only - no offroad whatsoever
This is a debate a bit like engine oil - we all have our own opinion.
Personally, if I intend to keep a bike for a while then I stick in a K&N to save money in the long run.
I don't think it gives any performance benefits - in fact some people say it takes it away.
I clean my K&N at least once a year (approx 8K miles) just because I want to. Some will clean it more often and some less often - depends on milage and conditions you ride in i.e. dusty, muddy, sandy etc.
Put yours back in and don't worry about it.
I recently put in a K&N filter and noticed the mid range performance was much better. I also installed a pre filter fully covering the K&N which leaves it completely clean, its been in 6 months or so and there is no dirt whatsoever. I will be keeping mine in. I do get slightly less mileage tho, about 10/20 miles less per tank, but that could be my riding harder through the mid range. who knows. i really like it and it survived winter no probs.
I have the steptoes cat code jumper changed to straight through and a straight through can with baffle removed. so bear this in mind with your own individual setup.
Check your spark plugs and see if your engine is happy or not.
Got rid of my K&N, noticed it let particules past after a morrocan trip, and you really don't get any performance benefit.
Gone back to original filter, £6 each ( even cheaper if you buy them in 10's) and throw them away every 12k miles. Which would cost £60 for 120K miles of riding, so i can't see how using a K&N would save you money once you've bought the filter, bought the cleaning fluid, and bought the K&N filter oil, and spent time fecking around cleaning it.
Then you also have the potential problem of premature engine wear due to the K&N.
You're da man, Neil:thumb2
The unused BMW paper one is going back on and I'll change it yearly
What he says is very true and easy to test. just remove the KN and with a damp songe clean very carefully the airbox. Replace the KN - newly cleaned/reoiled. and ride the bike.. Then after a few months take it out and rub your finger round the inside of the airbox - downwind of the KN. You will be absolutely horrified by how dirty your finger will be. Thats the muck that adheres to the airbox - just imagine how much has got into the engine. The things are a menace on road bikes.
