Kicking the Cat!
WOODY
WEST
Im sure I read somewhere that someone got rid of the Cat and kept the original MBW silencer on?
Does this configuration improve performance or fuel consumption?
Do you just need a standard Y piece ?
Im on an 02 single spark ADV and if I make the mods does this affect the Chip settings:confused:
Many thanks........:beerjug:
You can just bung a Y piece on with the std can and then later (if you want) get a shall we say a lighter end can.:D
Loads of info on site, try the search tab at top of the screen.
Cheers Finglonger I will give it a go........Loz :beerjug:
thats what I am going to try
seems to give a bit of oomph without setting off car alarms
apparently you need to make sure the seals are 100% sealed unless you like poppy farting noises;)
