Removing the cat ....
Bobbin-Man
Chester
I finally decided to dump the cat!
I'm not interested in having an alternative flee-flow silencer because I really don't want the noise but having read extensively on here, I decided that keeping the existing system and getting rid of the cat was probably the best choice without dangerously running into lean mixture problems.
Whatever I do to the bike I tend to keep the original bits to enable me to return the bike to standard if I want to, so first job was to source some replacement downpipes. I've kept looking but everything has been either over-priced or tatty but then last week I found a set for sale in Northern Ireland for £60.
Downpipes received and other than one very small stone dent on the underside, pretty well perfect condition. So how do I remove the cat? After a bit of a search around the net it appeared that it's simply a case of getting into the cat bit of the pipework, drill/chisel/hammer/hack whatever's needed to get the cat out and weld it all back up. Initially I wasn’t sure how tough the stainless steel pipes would be, but surprisingly it was easy to cut through with a couple of new 12” hacksaw blades. I made the cut where the rear clamp is fastened so the new weld would be hidden when finished.
The cat is contained in a short section of additional pipe inside the main exhaust pipe, so there are 2 options, either remove just the cat material or remove the cat ‘pipe’ complete. I decided to take out just the cats internals so I drilled a series of holes round the outside of the cat, then some easy work with a wood chisel all that remained was the extra piece of short pipe.
I then took the empty assembly down to JP Exhausts in Macclesfield who are a specialist stainless exhaust manufacturer. They looked at the 2 halves and then asked “Is it plated? It certainly looks like it is.” I hadn’t even considered that the new downpipes I’d bought might be the chrome version rather than plain stainless as my old ones! It seemed that welding might now be an issue but they’d see what they could do. Literally 10 minutes later one of the lads arrives back with my pipes, I’m thinking bad news, he’s looking happy with himself and wow, some impressive welding! Side by side with my old pipes the new chromed assembly is a far nicer piece of kit, how much cleaning it’ll need to keep it rust free I’ll just need to wait and find out.
The result ….
I rode 2-up down to the NEC for the bike show yesterday, icy A-roads going and a deluge on the motorway coming back, but a little over 200 miles to get a feel for any change catless. Other in the past have ranged from no different to massively better - my personal experience is that the engine has lost its’ small-throttle-opening hesitancy that was a real pain previously, making it much sweeter maneuvering at low speeds. Also the mid-range pickup has improved, very noticeable with a pillion. Top end power? Unlikely to have changed and I don’t really care! I find the power of the GS ample it’s just the smoothness through the rev range that needed a little tweeking and this has really helped.
I’d already fitted an Accelerator Module and that helped a little, but this has been a much bigger step in the right direction. Might still be tempted to get a Hilltop remap but now it’d be more for peace of mind over the mixture than the actual rideability. Also I've always recorded my fuel used and mileage so over the next few months will know whether economy has improved.
Sorry about the poor quality iPhone pics.
Stu.
I trust you disposed of the cat properly? There is some very nasty shit in there....:eek:
thanks for posting should be a big help to anyone thinking of this mod. i was thinking of changeing my gs when a chap walked up to me in a bike shop and said "is that your gs outside and would you like to buy full remus de-cat system", i did and any need to change my bike ended because it was a very different machine after fitting, every aspect is better, only downside hot exhaust gases caught edge of number plate which was to big anyway just replaced it and moved it about 4mm over. felt no need to remove baffle like you not intrested in making a noise.
My local garage services guy is having it ... apparently I can weigh it in as scrap but not got the time!
Good thread , i am thinking of doing the same myself.
what year is your bike ?
is the exhaust made of stainless steel , or is chrome plated ... ?
does this differ in the years of manufacture , or are they all the same ?
regards
Tony :thumb
regards
Tony :thumb
2006 bike. Original exhaust was stainless new one is chromed, although I understand the chromed versions are the same stainless exhaust underneath. Not all stainless is equal though and this was pretty easy to saw through.
Stu.
I'm going the other way, replacing the whole system so the standard cat system can be put back if I ever want to.
Im expecting a remap to improve fuel consumption because it should be possible to set the mixture for a better balance of economy and power
Normally the engine is run slightly rich to fuel the cat to burn off all emissions. How successful they are in the real world compared to a correctly controlled non cat engine is open to argument.
For what it is worth I was able to remove the core without cutting or welding using simple hand tools and some elbow grease. You just have to be careful not to distort the opening that the muffler slides on. A simple hose clamp around the opening while you are working helps to keep it round. It took about two hours.
Why not a set of non-cat downpipes? Used need not be costly though more than a hammer and chisel I guess. Dont forget the cat must not be dumped into normal waste. Take it to a metals recycler
Then the bike can go back to standard if you need it to.
Take a bit of care what you are breathing in when you smash your catalytic converter to pieces.... Some of the residues won't do you are whole power of good if you are a bit unlucky.
I removed my cat
I took him to the vet and had him put down.
No change to my breathing but my daughter can just about stay in the house now without risking an asthma attack.
Having said that you could have my new GSA, my R100R and my C1 if I could have him back as he was even if only for a year :tears
Dutch what year bike did you do this on Twin cam?
If it was a TC has it made an improvement?
And what about fuel consumption?
Thanks Nick
