Last minute dot com route planning
Mad Hatter
Ain, 01, France
Well I woke up this morning and said bugger it I’m going for a ride. I headed south east’ish from Bourges, avoided major roads, and at the end of the day I’ve ended up in a place called St Jean de Maurienne, which is in the alps. Cracking days ride but 36c in the afternoon which was rather warm.
I’m going to spend tomorrow exploring and then head back to Bourges on Wednesday.
Looking at the map it appears I’m surrounded by famous mountains and cols.
Does anyone have any suggestions for a full days ride in this area in some sort of circularish route, taking in lots of cols and ending up not back here in St Jean de Maurienne, but somewhere say within a 150km radius?
Back in 2011 I rode some of the unpaved high altitude military roads somewhere near Sestriere so I might head that way
I am not to sure what you mean by, “A circular route. Not ending up back in X…. but somewhere else” but how about:
The entire circle is 150 miles in diameter.
You could amend it a bit by mucking about in the bits with the red arrows:
Stop / end wherever you like, logically somewhere that suits you for the next day.
Thanks Wapping. I’d like to avoid Grenoble if possible. I was just playing on Apple Maps and came up with St Jean to Col Galiber to Col Lautaret, to Fenestrelle to Susa, to Col Mont Cenis to val d’Isere to cormet du roseland, ending up in Albertville for the night
Cormet du Roseland ,one of my favourite roads in France .
Loads of options, as you say another day of great roads then head home I thought it does not need to really loop back, so how about 8-9 passes including some of the French Greats incluidng Galibier, Izoard, Vars, Allos and ending the day riding around Gorge du Verdon, should leave you in a position to get home easily the next day.
Well, what an epic day I’ve had!. Here’s what I ended up doing….
Started this morning at St Jean de Maurienne. Slightly later then planned thanks to stupidly locking the bike/pannier key inside the pannier (don’t ask, it was an expensive mistake because I had to break the pannier lock to get the key out).
Setting off at 10am I first went up the Col du Telegraphe en route to the Col du Galabier. Very majestic scenery up here and fantastic visibility. This was followed by Col du Lautaret which was more of the same, then along the valley to Briancon and up over the pass and into Italy to Sestriere. At one stage I got stuck behind a coach and couldn’t pass for ages, so I ended up singing the Italian Job theme music to myself to pass the time, hoping the coach would go over the edge.
From Sestriere I went across to
Balboutet and up the hill on a tiny little tarmac road to the Colle delle Finestre which was 50% gravel on the other side. This was a great Col to ride because there are lots of really tight hairpins and it’s also pretty steep downhill on the gravel. Highly recommended. Also there is a route to the left part way up the Colle delle Finestre which takes you on a long gravel road to the Colle del Assietta which is equally brilliant but I’d done that one before. After Finestre I dropped down into Susa and then went up Col du Mont Cenis where the turquoise lake was stunning in the sunshine. After than it was onward to Col de l’Iseran which if I’m honest I’d have to say was pretty intimidating because it was cold, barren, windy and gloomy up there and the roads are very exposed with lots of sheer drops and either no guard walls, or token efforts just 6” high. The road surface was pretty sketchy too. I’m glad I did it but it was more enjoyable afterward than during! A hot chocolate and quiche followed in val d’Isere and then I followed the valley road all the way along to Albertville and my less than salubrious Ibis budget for the night. I was going to do a spur off to do the Petit Mont Saint Bernard but ran out of time thanks to my key disaster in the morning.
Favourite of the day was definitely the Colle delle Finestre. Highly recommended if you’re out that way.
A good day though
Thanks so much for this. I plan to be in the very same area next month, and you've highlighted some of the exact roads I want to take. Keep it coming! 👍😎🙂
If you are up for riding on gravel I can highly recommend it. I took this photo at the exit of the Colle del Finestre. It shows the high altitude gravel roads in red
Most awesome! Thanks loads for this. I'm chomping at the bit but have a month to wait. First stage of the trip is to make my way south west from Memmingen catching a few Italian and Swiss passes along the way.
Then base myself close to the French Italian border and enjoy all the Cols and trails I can find.
One question, would a 1250gs with road tyres cope with the trails?
Yes, no problem re tyres. My Africa Twin only has Bridgestone AT41’s on it which are essentially a road tyre and I saw lots of GS’s there with similar
