led adjuster
AussieinBelgium
Belgium
Hoping to get a answer from a member Slipperyeel . I need an adjuster for a Aliexpress LED headlight conversion for a 2009 BMW gs Adventure
Hello!
I think my first question is to confirm you have the correct version of the headlamp. Doc attached that has photos of the correct lamp (it's the version that most resembles the OEM ovoid shape)
Hello!
Yes I have the aliexpress led headlamp for my GS. It has the three mountinig points like the facfory orignal.
Am I correct in saying the adjuster shown in the pdf on post #3 is a cool addon - to replace what the aftermarket lamp unit has as std, ?
and is this because the std one breaks, the std one is very basic, or even comes with nothing
the aftermarket has only three mounting points the three underneath just uses the orignal factory rubber gromet. There is no up and down beam adjustment therefor making the light bean to low. The adjuster you make i am hoping that it makes the lamp beam adjustable
The OE lamp has the adjustment mechanism within the housing, which itself is fixed. This can give trouble if it sticks or the ball and socket arrangement comes apart. The LED one doesn't have this and the whole unit pivots on the two side fixing screws to adjust. The adjuster slippery eel makes attaches to the underside of the LED lamp and locates on the peg on the subframe. Gives more rigid support to the LED unit and easy adjustment. It works a treat and is highly recommended.
Comments above correct ref no simple way to assist the AliExpress headlamp.
Small to for everyone - with the adjuster fitted, to enable it to work, you don't want the two main side bolts really tight, otherwise it won't want to tilt. So there's a sweet spot of backing of two big bikes just enough to allow the micro movement offered by the adjuster 👍🏻
If wanted, I can provide an abs washer to place between the main bolt and the fitting it passes through.
I just slacken off the side screws and then re tighten after adjustment. The ability to make fine adjustments is very welcome.
