LED Headlamp adjuster
The C shaped one comes on with the ignition. The dipped/ low beam comes on with the engine started.
At least mine does that.
And I never needed the adjuster on mine. I just fitted a rubber grommet in the hole in the base of the light and wedged it in so the headlight was as far up as it would allow and it is pretty much near perfect for me. 👍🏼
Like I said I’m special. Maybe my spigot ‘plate was welded on a few degrees off.
On a different note, those of you that may are running OG front shocks, where are they set? I’m heading out for a spin Sunday.
The suspension has 9 clicks.
I’m here giving out about cheap well made Chinese shite, was rolling on + 1.
As a side note has anyone made a acrylic headlight protector for these yet? I've just bought a sheet to try and make one. I'll feed back when and if it works.
IIRC, on the GS the rider sag should be 40-50mm (measured as forl stanchion travel) at the front and 60-70mm at the rear ( measured as axle vertical movement).
@Comfy Old Boots you should not have to compromise your suspension settings in order to get the beam angle right 😉
I am surprised that the head light unit has no adjustment itself, TBH
Adjusting the suspension to adjust the lamp was a joke 🙄
Of course the OEM candle can be adjusted. But these aftermarket upgrades (this is very definitely an upgrade) don't come with an in-built adjuster, unfortunately.
Small update.
Now printing an extended version for Comfy old boots. See pic below comparing the two.
This 'extended' version is 13mm longer. It requires a longer bolt... So it's more than just a modified adjuster body that's needed.
Before I make any more of these - I need your feedback Comfy.
My only reservation is if that 13mm added projection into the cockpit area fouls anything? An important detail!
I must reiterate, that this is literally the first feedback ever with this issue. But as I hope is clear, I am keen to correct it.
Just a quick update on the headlight protector. £15 all in but took a while.
I used to have the genuine BMW ckear protector. I removed it because it reflected too much light back. It was not the loss of light ahead, more the amount of light could make it hard to see ahead in the dark.
Maybe you could add some sort of mask over the upper gap between protector and the headlight surround?
Thanks for that. I have read that some people put tape over the top to stop this. I don't do much riding in the dark to be honest, I converted to LED for visibility in in the day really.
I just took delivery one of the adjusters and an Aliexpress headlamp and on a dry run of installation noticed something which could likely be the source of Comfy Old Boots' problem.
It seems that on the headlights currently being delivered the headlamp lower hole that the adjuster moves within is now round rather than elongated, resulting in a restriction of adjustment range and potential breakage of the sleeve on blue part. For the adjuster to work correctly this hole needs elongating to the rear by about 5mm or opening out to a slot.
Showing lower mounting with adjuster.
Removing the two large allen bolts allows the rear plastic cover to be removed.
Allowing easier access for the hole to be elongated.
The alloy of the lamp main housing is quite soft and easy to cut/file.
Thanks for this Fith Horseman. I think you may well be right.
The modified unit will be on its way to Comfy old Boots tomorrow. I hope with him before end of next week 🤞🏻
The modified part is only the chassis part with the adjuster wheel attached. The mounting part that is stuck to the headlamp doesn't change.
If this works, then I will post out to whoever needs one for.
