Light Bar Installation with HID and LED Daylight Lamps
tyclyd
Gary
Brecon, Wales, UK
After my previous post about fitting LED running lights alongside my existing old HID extra lamp and the abortive attempts in making a light bar bracket from angle and flat bar I bit the bullet and paid for a Migsel Light Bar - there was a bit of a delay as they were out of production but the factory kept me well informed and last week it arrived after about 14 days . I have no connection with this Belgium supplier but was very impressed with the quality of the finished item which is made from stainless steel and laser cut and folded with a bead blasted (matt) finish.
Installation was easy after I had removed the homemade elbow bracket for my old HID Light and re fixed the GS Beak with some thread lock. Two new stainless Hex bolts are provided and I packed these out with a 2mm washer on the upper edge and a small spring loaded washer on the bottom and again a light smear of thread lock to stop it all shaking loose.
I decided to refit my HID on the underside LHS and had to adjust the drainage tubes which I fabricated out of some 2mm black pipe I had spare and then fixed the new running lights on both side above the HID.
The remaining wiring loom I tucked into the under seat space and I have some final heat shrinking of the loom to do next weekend but I was very impressed with the product and the final finish.
Not much
No they don't stick out much at all - certainly narrower than the bars and well inside the tank and a bit inside the engine protector bars on the ADV - worth paying for the product I think seeing as my fabrication skills are "amateur" at best...
