This seems much more reasonable on price for the same thing:
http://www.shoraipower.com/s-101562-R1200RT.aspx
And some interesting stuff in their FAQ section:
Q. I hear that lithium crank poorly when it gets cold, is that right?
A.Lithium do increase in resistance more as temperature drops, compared to lead-acid. However, they also react to cranking under cold conditions in a much better way. Lead-acid will increase resistance on each subsequent cranking attempt, until it won’t turn over. If your LFX fails to start the engine on first crank, that first crank has warmed the battery, and the second attempt will be much stronger, and so on until you get a good start.
Shorai LFX are much better in cold-weather conditions than other-brand lithium starter batteries, due to our eXtreme-rate formulation with low resistance. Down to about 20 degrees fahrenheit (-7C) most users find that they can start normally on first crank. If your headlight comes on at key-ON, it is good for the batteries to flow some current before cranking in cold weather. The suggested headlight-on time before cranking depends on the temperature. If starting at 40f (5C), 30 seconds will help wake the battery and increase cranking performance. If at 0f (-17C), leave the lights on for 4~5 minutes before cranking. The result will be a better first crank, and longer battery life. Any other accessories that can be turned on before cranking can also be used for this purpose, such as heated gear, radio, etc...
