Lost key fob
Doc
Ey Up
Slawit
Hi lads What's the score for getting another key fob ? Dealers and do they just reprogram a new one.
Cheers Doc
Yep. They will happily sell you one and program it to the bike. I can't remember the cost, but it's not cheap....
Cheers pal. I have misplaced mine somewhere so dont have a spare.
:green griNot any more.. only one fob issued
Twin Cams had two fobs.. fairly certain they went to one with the M8
I only got one..
Well I got two and now down to one so it's all good then if only one is issued.
If you bought second hand, the previous owner may have bought a spare - or at some point between 2017 and 2021 HD stopped issuing two..
Doc - it is no biggie if you loose your final fob / read the manual and learn how to post the override code in…
I’ll not post it here for obvious reasons.. if you have not changed your factory pin - you should do ..
Quick Google tells me then went one fob from 2020MY
That’s why I only got one then!!
Arsey your prior owner still has your spare..
Cheers I didn't know that but then again never read the manual. So presume if I do that and loose it while out I can start the bike ?
Yes- you set a pin and access it through the indicator buttons.
Let’s hope the previous owner told him the pin……..
