Deleted account 191119001
- Joined
- Aug 13, 2017
- Messages
- 12,798
- Reaction score
- 9
Don't know what an 'Orange programming key' is - I certainly don't have one.
I have a single black mechanical key, but nowhere to put it. Dealer says its electronic and to place is next to the antenna. That doesn't work.
Thought most KTM,s came with the Orange key to reprogram up to 4 keys in case of a lost key.
The orange programming key must only be used for activating and deactivating!
If a black ignition key is lost or needs to be replaced, the individual black ignition keys need to be enabled or disabled using the
orange programming key. This prevents the vehicle from being operated with the lost black ignition key.
You can activate or deactivate up to four black ignition keys. Only the black ignition keys programmed during an activation proce-
dure are valid. All black ignition keys not programmed during the activation procedure are invalid, but can be reprogrammed in a
further activation procedure.
Loss of a black ignition key (additional black ignition keys are available):
The following procedure deactivates all activated black ignition keys that are not
included in the procedure.
– Press the emergency OFF switch to the position ON
– Insert the orange programming key in the ignition lock.
– Switch on the ignition by turning the orange programming key to the position ON
– Switch off the ignition by turning the orange programming key to the position OFF
– Pull out the orange programming key.
– Insert the black ignition key in the ignition lock.
– Switch on the ignition by turning the black ignition key to the position ON
401114-10
Immobilizer indicator lamp
L01453-01
lights up.
lights up.
.16
ELECTRICAL SYSTEM
146
– Switch off the ignition by turning the black ignition key to the position OFF
– Remove the black ignition key.
The immobilizer indicator lamp flashes according to the number of func-
tional black ignition keys including the orange programming key. In this case,
it flashes twice.
The lost black ignition key is deactivated.
The existing black ignition key is reactivated.
Loss of all black ignition keys (no black ignition keys are available):
This procedure is important to prevent misuse of the lost black ignition key.
401114-11
.16
ELECTRICAL SYSTEM
147
lights up.
it flashes once since all black ignition keys are deactivated.
L01453-01
– Order a new black ignition key according to the key number on the KEYCODECARD
and activate it.
All black ignition keys are deactivated.
To activate up to three black ignition keys:
lights up.
lights up.
– If two other black ignition keys are to be activated, repeat the last steps with the
respective ignition key.
.16
ELECTRICAL SYSTEM
148
– If the last black ignition key was activated, insert the orange programming key into
the ignition lock.
Info
Activation of the ignition key is finished.
To activate four black ignition keys:
lights up.
lights up.
– If three other black ignition keys are to be activated, repeat the last steps with the
.16
ELECTRICAL SYSTEM
149
Info
After the fourth black ignition key has been activated, programming is fin-
ished.
