vfxmark
While poised to park, a very nice but unobservant woman in a very fancy car reversed into where I was about to park. Wedged me over and bike dropped gently onto left rocker cover and ratcheted around in circles until I could turn it off.
20k miles earlier, I had slid down a clay road on that rocker cover, hit a rock and caused a small crack, which I "temporarily" fixed with JB weld and a bit of chromic acid conversion stuff... not a dribble of oil since.
On getting home, found I was dribbling a small amount of oil into the spark plug tunnel which was wicking out past the plug cover and oozing out under the plastic plug wire thingie.
Ahh, says, I... the impact must have compressed the inside doughnut gasket...
so a few hundred miles later, I do my 30k service, and replace that gasket with a new one.
Run the bike a bit, and sure enough, it's weeping a bit through that same place.
Maddening in that it drops a few drops of oil if I leave the bike on the sidestand, and if I put it on the centerstand, it only adds a bit of oily sheen to the rockercover with a bit of dirt on the starter cover etc.
So... anybody have any thoughts on this? Would the impact of the bike tipping over have compressed the rocker cover gasket enough that I am now overtightening the center doughnut? Should I replace the doughnut again and also replace the main rocker cover gasket? I can't imagine this slow impact moved anything else enough to cause a prob...
Even as the US credit rating has been downgraded, I still have enough money to replace the rocker cover, but I dont mind the little jb weld discoloration (which is absolutely NOT leaking) and I know that the minute I replace the rocker cover some idiot (probably me) will knock the bike over and scratch up the new one...
If I do nothing but pull the plug/coil cap once in a while to drain the oil, it will probably not be a problem for the next 30K miles... the issue is really cosmetic and conceptual more than operational...if my triumph had sealed this well at its best I would still have it
