Exile WCB
Need to buy a manual. Any recommendations? There's the trustworthy Haynes manual but I've seen a make called Clymer. Any experience of this company?
Aside from the standard servicing I'd like to do, I have a problem with the fast idle. It's not very fast. The revs only pick up if I hold the lever right up and even then it's not much. Means that the engine initially ticks over slowly and if I blip the throttle it cuts out. Not until the engine has warmed up a bit does it subside. Really only a problem in the cold mornings thankfully.
I suspect it may have something to do with the BBR performance chip fitted. Never fitted it so not sure. Anyone any experience with this? My plan is to figure out how to adjust the fast idle and troubleshoot from there.
