Morning all,
I've spent a few weeks searching online with no luck. I cannot find a close match to the symptoms on my bike. It is a 2002 single spark 120,000 mile GS which I've had for a long time. The problem started a few months ago and now it's starting to annoy me. The idle speed varies between 1,100 and 900 RPM. It doesn't hunt. If it's not at 1,100 it is at 900. When at 900 it feels like the bike is about to stall but never does. I can fix the issue by lifting the fast idle lever a tad and then all is well again. The problem is apparent regardless of weather, air or bike temperature. The engine will idle at 1,100 for around 30 seconds before dropping to 900. The engine performs as well as it always has and pulls like a train from 1,200rpm to 7,500rpm with no issue at all. No hiccups, coughs or splutters. Perfectly smooth no matter the revs - well, as smooth as an 1150 boxer ever is.
I know I need to refurbish my knocking throttle body but I don't think that could be the cause. I fitted new spark which made no different plugs at the weekend.
I wonder if one or both of the HT leads are degrading but wouldn't that make the bike run rough at all revs? As I said, it doesn't it's just that damned idle speed dropping after 30 seconds.
All wise words will be appreciated.
Regards
Rob C
Regards
Rob C
