RT speedometer problem
Wrigsby1
AB51
So my 79 RT has been ridden on and off during the spring/summer.. it's always had a problem of a badly fluctuating Speedo... It would start as a vague wandering needle then go into a very jolty Speedo that seemed to be sticking a bit...
I've did the obvious things of replacing, lubricating and re routing the cable but it's definitely in the Speedo head... Its ended up breaking the needle which is a PIA...
I've broken the clock housing down and I'd say it's likely the spinning magnet? That goes into the pickup for the needle..
The magnet part and the housing to the needle have lots of play... Is that how they are?
Because the Speedo is pretty inaccurate anyway I've emailed Acewell with no response yet as to availability...
There are 2nd hand ones?
I could mount a secondary accurate digital speedo but I'd want to keep the odometer but not the problem speedo...
What have others done or sorted that might help...Any tips would be appreciated as it's one of the few things to iron out and I like using the bike...
Also if anyone has fitted a different unit with success...👍
I've got one or 2 spare speedos - what ratio is yours and I'll see if I have one. Could be a source of parts in the very least.
Being thick here, is that the diff ratio or has the speedo a ratio ..?
Speedo face has a ratio stamped in white under the MPH logo.
Thanks Kenny... I never knew... Learnings great and endless...👌 The clocks setup are a quality build... What do you use as a lubricant on the nylon gears? All help much appreciated...👍
Here the photo of the face... And the broken needle which was probably brittle and didn't like all the jolting action...
Well, I've got 2 whole speedos (both W 1.112), one with 77617 miles, and one with 01999 miles. I also have 2 speedo needles/hubs ready to fit. I'll do pictures but we all know what they look like! DM me if interested.
Pinged you a message...👍
I would like to say thanks for advice with this and Gelandestrasse for advice and spares that will hopefully sort it... All built up again and just needing mounting back to the bike... 👌
Good old UKGSer stuff as with the Oilheads section...😀
