Darryl said:
hi Chuck
Are the LED's mounted on the bike or the boxes? and if they are on the bike is their visibility and the backlight obscured by the boxes.
Have you tested them fully loaded? as they mount so far back it looks as if they may lighten the weight on the front wheel
and how much are you hoping to charge for the system?
Darryl
We have concluded that the currently available LED turn signal solutions are not feasable due to visibility and viewing angle reasons. Therefore we include a very bright DOT/SAE approved turn signal replacements that are 3 inches wide.
With regard to environmental testing, yes we have completed a thorough series of tests related to weight, vibration, heat cycling, loads with varying speeds, water/dust prooofness, mounting/dismounting cycles, installation, door open/close cycles, etc.
We have orders for 18 sets and have shipped a majority of them.
My partner and I just concluded a great trip to Hyder, Alaska with our Pilot luggage. The luggage worked great under all conditions and we had a high interest factor by all motorcyclists when they saw the luggage in person, first hand.
Comments were glowingly positive and constructive. The cases look right on the GS and provide a very large convenient means to carry your gear.
Cost is US $1299 for the cases including the mounts. All components are either stainless, CNC 6061 billet aluminum that is anodized or 5052 aluminum for the case panels.
NO mild steel components exist in our system. We wanted first rate material and finishes for every component of our luggage system.
