This morning in my local Lidl.
A ULTIMATE SPEED branded portable tyre inflator pump.
The pump does charge via the supplied 3.6* USB-A to USB-C cable and included dual USB-A 12v ciggi outlet adaptor. Doubles up as a phone/ipad charging cable if you are sat more than 0.5m away from the socket.
And yes it is noisy. Like any compressor is.
Size: 24x6.5x5.7cm or 9.5”x2.5”x2.25”
Weight of the entire set including the supplied storage bag, charging cable, adaptor and supplied accessories 670g
The pump and inflating adaptors/accessories 574g
The spec:
Included inflating accessories/adaptors
Unit features an LED torch with three light output setting.
Continuous on.
Fast strobe.
SOS mode.
Nothing amazing, but good enough to find your way inside a top box/pannier/campsite/tent should you need to find your tools or indeed anything else in the middle of the night.
It is also cleverly placed, so that you can still use the light output to find your valve stem on the wheel.
The inflator hose is only around 125-150mm long. And the free spinning adaptor end isn’t the best of quality. I will see how well it does perform, but I will likely want to replace it with something a bit longer and better quality. It is though good enough to get one out of trouble.
All in all, it probably will take about same amount of space as your airman pump. But being long and slim, it’ll probably also fit a bit better inside your top or indeed toolbox.
The display and buttons.
Power on/off button. Latter requires pressing and holding for 5 seconds to turn it off.
Pressure gauge adjustment via +/-
Torch
And inflator activation button.
Display showing pressure units by default in Bar. By continuously pressing on/off button you get a choice of psi and kg/cm2
One thing to note, that the unit does need to have charge in order to operate. It will not work whilst being plugged into the USA-A/C Outlet. In other words it can not multitask. So be sure to have it fully charged after using it
Included is the instructions manual.
