Sixpack
Looking for some advice again I'm afraid. I have a 1200gs 55plate and on Monday it started to have a slight misfire at half throttle in 6th gear. I set off home from work and it seems to be doing it in every gear now. It only seems to do it at half throttle, when the throttle is fully opened it's like hitting a power band and off she goes. I don’t know if it's significant but i fitted a full Bos system about a month ago and it's felt like there has been some flat spots but nothing serious. I was going to try swapping the exhaust back over to standard to see if this helped what do you think?
Thanks,
Sixpack
Thanks,
Sixpack
If so you may have disturbed a connection under the pots when removing and replacing the O2 sensors.
