2011 R1200GSA slight misfire
mpgscott
Isle of Scalpay, Western Isles
Odd one, I’ve replaced all coils. Balanced the throttle bodies and valves done 3k miles ago.
Recently full service and bike seems to run nice when going.
Done recently around 2500 miles and it’s just started this.
When you come to a stop it sometimes sounds to be idleing slightly high. On off and it will be ok.
I’m seeing today that sitting at lights it will tic over nicely then sometimes just gives a little miss at tic over. Sometimes if you just catch it wrong it could just about stall when you take off if that makes sense.
Any ideas what it could be?
Once your going it seems fine doesn’t se to miss when riding it, only at idle once you come to a stop at a junction for example.
It’s not all the times, very odd.
my thoughts greatly appreciated. Away to do a trip to France so if there’s something up I’d like to try and remedy before next week.
Mark
I read it here that these wee caps can cause such issues, check how tight they are on, any tares or perishing of the rubber?........might want to try that before going deeper.
Good luck.
Mine (2010 GSA) was kinda playing up like that earlier today, put it down to the high temperatures. Didn't give it another thought after that.
I think these bikes have gone through deserts before without issue, a Scottish climate is never that hot to bother air cooled bikes.......or BMW would be in trouble. :D
Yep, this is why I’m thinking somethings up. Done all the usual culprits so kinda head scratcher..
  • Like
Reactions: HxH
Have you recalibrated/synched the idle motors ?
Believe so, it’s a step on the GS911 for the throttle body sync isn’t it? You lick the them at start and then adjust off top of my head.
All seemed to run though correctly when I did them and got them balanced nicely once new coil packs were fitted.
View attachment 519284View attachment 519286
Good luck.
Thanks for this, checked and they’re both there and in good condition. Good to check though so thanks for suggesting. 👍
  • Like
Reactions: HxH
Dirty fuel?......did you just fill up before all this happened?.....some petrol stations are not the cleanest in my view, I know I used to deliver to them.
I posted this in the TPS thread but here it is as well
Yeh, I’m just chatting with Ivan, well worth a shot me thinks.
I did check the sensor operation when I was doing TB’s all seemed ok. However can’t tell as the old mechanic states that it’s not worn out.
See what Ivan tells me.
Thanks for the info.
Can you keep me updated please as I’m very interested. My bike is a 2013 one of the last K25’s. I have a big trip planned for next year and I want it right.
Ive today swapped in another TPS kindly given a temporary shot from a fellow member thankyou Mart.
So it’s fitted and it’s been started up and left running for a wee while, cycled a few times. I’ve a 5hr stint tomorrow so will see how it goes. If all well I’ll get one of these ordered when I hopefully return from venture to France.
Mines still giving the occasional splutter when you come to a stop.
Dam, was hoping this would solve, I’ll continue to see how it behaves over coming days.
Bike is just so nice on the go, that’s a couple of hundred done on the twisties today.
