Hi all,
I tried using my new Mityvac pump today, it happy sucked all the old fluid out the master cylinder reservoir. I then connected it to the near side front caliper, opened the bleed valve and started pumping! initially some old fluid came out but after about 10 seconds no more fluid was coming out (despite continued pumping) and the fluid level wasn't dropping in the master cylinder reservoir (lid off).
In the end I bleed the brakes the old fashioned way, which worked fine.
Am I missing something obvious when using the Mityvac? The pump is working ok as I was able to remove the excess fluid from both reservoirs.
