more sump spacer "Q"
sump spacer
Why bother fitting a sump extender onto a bike with an oil cooler :confused:
Use the same dipstick after fitting mine, and as I don't have an oil cooler I think it's a worthwhile addition.
my next question!!!!! can you re-fitt the engine into the frame with a sump spacer fitted or is it best to fitt the spacer once the engine is back in the frame ???
:augie
I don't know, but the question is, how much clearance was there when you took the engine out?
Try and google "crankcase pumping losses"...
I've got a spacer ring that I have never got round to fitting. The plan was to run the bike so that oil volume was increased slightly and pumping losses reduced slightly.
Just my 2p...
Sean
Is it for sale!!
Any ideas on where to get the best deal on said item:comfort
30-mm 1.3 Liter more :)
€69 Plus €23 for the gasket set:( plus p&p €15
All the rest come to more money -
BMWboxersupplies - €106 inc gaskets + p&p
Boxerparts - €82 + gaskets + p&p
Siebenrock - €95 + €11.60 (gaskets) + p&p
Not that much to choose between them
John
John
Thanks Red, Any one got a spare one they didn't fit drop me a PM" before I buy new.:thumb
Adding postage to Oz at E48- made the spacer an expensive exercise , so I have ended up with the deepest finned sump that BMW make, for around 120 quid less.
Did I mention that I am an expat Scot?
I will keep you posted on the difference , if any , that this makes to the oil temperature.
I have a sump from a 81 to 95 road bike, that is, not a GS.
I have the longer pick up too.
There is a link in an earlier post to Antons site which has all the information on sumps
Motorworks lists a deeper sump as a modification using second hand parts for around 17 quid.
