mrTickle
I've just tried my first balancing act using the Morgan Carbtune II
http://www.carbtune.com/index.html
When I balanced the throttle bodies perfectly, to double check, I switched the bike off, swapped the Carbtune hoses over and then took another reading. The reading was different and not balanced ( i.e bodies perfectly balanced at 24/24, then swap hoses around & I get a reading of 24/22). If I put the hoses back on as they were, I got 24/24 perfect balance again.
If I then balance the 24/22 reading to balance at 24/24, as soon as I swap the hoses around, the balance is out again. Surely it shouldn't matter which way around the hoses are connected as they are both independant vacuum tubes? I should be getting a reading exactly the same regardless of what hose is connected wherever. Any ideas?
Can I balance the bodies one at a time by connecting only 1 vacuum tube? Would that work?
Oh yes, the carbtunes are also made in good ol' Blighty...
