Zigo
Body sync?
Have you checked the throttle sync at 4000 RPM? The boxer engine is sensitive to throttle imbalance, which can cause vibrations. Dealers would normally only check and adjust syncronisation at idle, using the workshop computer. I use the Twinmax sync meter, holding the throttle open at 4000-5000, then adjusting imbalance turning the right (or left, but only one of them) throttle cable adjusting screw carefully until the meter reads zero. Recheck after locking the adjusting screw. Some prefer to check sync under load, driving with the Twinmax attached to the throttle bodies, but for me it didn't make any difference from the static check.
Regards
Zigo
Regards
Zigo
When they took the shock off they found that the front forks were sticking.
