Toe Down
I was reluctant to post this thread having read many 'do a search' responses to similar queries. Well I've searched and not found the answer.
Having looked at plenty of posts and having spoken to Nippy Norman, I was expecting to be a 5-minute straight replacement job. I have the NN canbus adaptor plug so the wiring's not an issue.
What I'd like to know is where you locate the new horn?
I've got ESA suspension and there seems to be no room using the existing bracket with the horn facing the suspension unit (same way as original). On the other side there's a small frame tube that the tank and bodywork hangs off - not sufficient space and it would foul the forks on full lock.
Therefore I'm assuming that it's not going to fit using the original bracket/location and I've been searching for alternatives.
There's an indent on the inside of the R/H tank (viewed from the front) which I believe houses an emissions canister in some markets. There's a couple of threaded inserts which a bracket could be mounted off. It's possible to position the horn there using one of the flimsy brackets supplied with the horn, although it's still close to the forks and it does seem to shake and wobble around in that location and may well foul something over time.
Are there any other options? A photo of an ESA Stebel Magnum installation would be much appreciated
The sun's shining and I'm still in the bloody garage
