Mph to kmh
Wardy
France
Gentlemen, as in the title, need to change my Speedo from mph to kmh. Is this a simple task to do, or do I have to plug it in at a dealer, etc, etc ?
Cheers Steve.
From memory, my GS was dealer or GS911 only so unless it's in the menu I suspect it will be the same for your bike.
Why BMW chose to program it this way defeats me.
Cheers Steve.
disconnect battery
turn ignition on
hold down mode key
keep mode key pressed and connect battery power
digital display will go through a sequence of digital readings of which one is mph and kph when you see the reading you want release the mode key
Superb John, I'll have a crack at that. Cheers Steve
disconnect battery
turn ignition on
hold down mode key
What a brilliant resource this place is, when you have mines of information like John!
I know it's a bit late, but only just got round to doing this, as had to lift the touratech bowser off whilst fitting a fuseblock, brilliant works a treat. Many thanks John.
