Music - Sena 10U (Shoei) Galaxy S20, NAV 6
developer
Midlands, England
And a 2021 GS Rallye - what's the easiest way to play music into the headset?
Radio preferred, but playlist is ok.
The FM on the SENA is a bit sh*t.
Thanks :thumb
I have a Shoei neotec, 10U, use the tft to select playlist on iPhone, only use Nav 6 for visual so not paired to tft. Works great.
Thanks - I hadn't considered usung the Nav for visuals only.
I assume you pair the phone to the TFT - can you still receive calls?
Yes, phone works as you would expect, mine is a June 2020 and original software,
Clear all connections on headset. Turn off the bluetooth on the nav.
Connect headset to TFT
Connect Phone to TFT
Now that is done, you'll have control of all media and phone calls Via the selection wheel on the handlebar. You can see the music playing, and make and receive phone calls from the TFT. If you want the radio, Simply download a radio app onto your phone, I use the radio App. Your stations will be shown on the TFT.
Volume will be Via the headset. As only BMW communication sets work with the selection wheel.
Use the Nav only for navigation. I connect my phone to the Nav for weather, weather radar, Foursquare, Tripadvisor and Traffic. This is automatic Via the "Garmin Drive" app.
If you need any other help or questions, This group will have it all.
https://www.facebook.com/groups/195190591351953
Good luck.:thumb
