Johnwhit
I drained the sliders and put the correct quantity of oil in and did the air gap under zero load as it should be and the bike is working the small bumps better than before.
I read that the oil in the sliders is for lubrication only but in my test it does help with small bumps as you ride and I'm guessing the air as its compressed helps on small bumps and the shock does the rest, so if your front end seems hard and seems solid unless you hit big bumps I would check your sliders,
ride safe
John
ride safe
John
