Nav 5 use in Car
Dodger
Member
Surrey, England
As the Nav 5 is the best GPS I have I would like to use it in the car. BMW are quoting £80 for a windscreen mounting kit - yeh right! Has anyone come across a decent aftermarket product?
You can use a simple Zumo 660 cradle, but you get no audio facility. 660 car mount is much cheaper
* Nav 5 cradle includes speaker
* Zumo 660 cradle has no speaker.
Later if you found you wanted audio - you should be able to pair the NAV 5 to your car stereo (if it has BT) or through a cheap BT speaker on your dash.
You do need a power lead, just check the Zumo cradle has one.
If you want to listen to it, you'll need a Bluetooth earpiece.
