Ring Garmin support - a replacement battery for the Nav6 - exactly the same as you get from the dealers - is £13.09 delivered. Just got one for my Nav6 recently.
Interestingly the same battery fits both Nav5 and Nav6
Item number 010-11274-22
Thanks for that info, I've been needing a battery for a while. Process couldn't be easier tell them what you want, they check stock and then send an email for you to complete and pay for the order.
They are very cautious on the phone telling you that you shouldn't really be opening the the device to change the battery, he stopped with the cautions when I pointed out to him that when the unit was new I had to install the battery, and on the odd occasion when the device locks up, I have to disconnect the battery to reset it (this is why they provide a screwdriver to open the compartment!).
He did go on to say that it may not necessarily be the battery and I should consider getting it checked out, but I pointed out that at £13.09 it didn't matter if it wasn't the battery, but that I also know what the symptoms are of a battery not holding it's charge so, whilst there is a remote chance it could be something else, it is highly likely to be the battery.
So again, thanks for the info hawkeye.
I now just need to sort out the battery in my Sena SRL Bluetooth unit, little use during lock-down appears to have killed it, I'm lucky if I get 2 hours use out of it. I had this apart yesterday, I ain't going to be replacing the battery in that, it's too fiddley. I may have to send it back to the importers, Feridax, to see if it can be repaired, if not, it'll be over £200 for a replacement!
