alp
Hijacking the thread somewhat, but I am very interested in the Sena SMH10R, if for no other reason than it is less of a carbunkle on the side of the helmet than the SMH10. Can you give me your impressions as a user?
And do you use the Sena helmet speakers, or have you modded it to use in ear speakers?
Paul, it's certainly much less obvious on the side of the helmet. The battery is attached separately near the control but is also flat. The main lead from the control I've just threaded under the bottom edge of the helmet and all connections to the main lead I've made inside the helmet padding are small so unnoticeable.
I've installed the Sena helmet speakers and they give a very good sound with lots of adjustabilty for volume and since I always wear earplugs I can adjust the volume accordingly without having to fiddle with wires to ear speakers when taking the helmet on/off, but that's a personal choice.
To charge the Sena battery on the move they supply a cable with a USB one end for the control unit end and a plug in end for the bike socket but the one they supply is sized for the larger car type plug/socket and not the smaller size BMW have fitted on the LC. I'd like to solve that since if I ride without much charge in the battery I'd like to connect it up to the bike to make sure I don't end up with a flat Sena battery on a run.
