Nav v, iPhone 6 and interphone f4mc
Marlou
Berkshire
A little help please, I have the above set up on my 2015 GSA LC and when all connected every time I do something on the satnav the music breaks up from phone to headset. Just phone and headset is fine and always has been but as soon I attach the nav it all goes to sh1t...
Any ideas??
I'm no expert but think you have the set-up wrong; you have implied that you have the phone and headset paired, as well as each of them to the Nav 5.
I have an iPhone 6s directly paired to the Nav 5, and the Nav 5 directly paired to an F5MC headset (slightly different setup to you, but close enough I think to make no difference). My phone is not directly linked to the headset, so all inputs and sounds are managed via the Nav 5. I think your set-up is causing the F4MC to choose between the Nav 5 and the phone, causing the problems, whereas if everything is routed via the Nav 5 it can manage the switching effectively.
The only inconvenience is that I have to listen to music from the Nav 5, and updating tunes on that is a bit more of a faff than doing it on the iPhone.
Try binning the link between the F4MC and the phone and see if it all now works with the Nav 5 sat between them. Hopefully I've not misunderstood what you said...
I will disconnect the phone and see what happens, to be fair that does sound like what is happening.
What is the best way to transfer tunes from phone to Nav??
Many thanks
