To fix a BMW Navigator V not receiving satellites, perform a hard reboot by holding the power button until it cycles off and on, or try a master reset by holding the bottom-right corner of the screen while powering on. Ensure the device is outdoors with a clear sky view, as it may take 3–20 minutes to acquire a signal if it has not been used recently or has traveled over 100 miles.
Troubleshooting Steps
- Hard Reboot/Restart: With the device on, hold the power button for about 10-15 seconds until it turns off, then turn it back on.
- Clear View of Sky: Ensure you are in an open area, away from tall buildings, trees, or covered parking, allowing 5-10 minutes to acquire a signal.
- Check GPS Simulator: Go to Settings > Navigation to verify the GPS Simulator is turned off.
- Update Software: Use Garmin Express on a computer to ensure your device has the latest firmware.
- Master Reset (Erases Favorites): Start with the device off. Touch and hold the lower right corner of the screen, then power on the device while continuing to hold the screen until a menu appears to reset.
- Travel > 500 Miles: If the unit has been transported while turned off, it may take 3-5 minutes to locate its position.
If these methods do not work, it is recommended to let it sit in a clear, open, stationary position for up to 20 minutes to reacquire satellite data.
