Neutral Switch
  • Thread starter Thread starter Geezer
Geezer
Guys does anybody know where the neutral switch is located on the GS ???????
On a 12 they have a variable resistor mounted on the rear of the gearbox which also
serves as a gear indicator & neutral selection i belive.
m@tt
That goes for the 1150 also. (back of the g/box same unit as the gear indicator)
Had to change mine recently, £15 from motorworks.
Changed it at the same time as fitting a Y piece so the job was easy. The hardest part is digging the old wire out of the loom and re routing the replacement.
roddy said:
is this the same for the 1100, my neutral light lags behind when I select neutral ? or is this normal ?
cheers
Sorry mate I can't help you there
